TO-20 Head Removal
albert betts
09-16-2005 09:10:00
What is the best way to remove the head from a TO-20 without cracking it? I removed all retaining nuts and tried to drive a flat head screw driver between block and head to get it to release, but I'm having no luck,,,,I'm afraid I will crack the bead if I drive the spacer in two far,,,,Has 10 retaining Nuts..... ....Thanks Albert
Steve in Mo.
09-20-2005 13:53:10
 Re: TO-20 Head Removal in reply to albert betts, 09-16-2005 09:10:00
Just a note if you are doing a valve job. Before you get the work done be sure the head has no cracks. Mine was cracked and it did not show up until the work was in progress. I was luckey and know a great welding shop they where able to fix it for me and it has been fine.
albert betts
09-16-2005 11:49:19
Sorry for the bother, page 3 of the shop manual plainly says to remove 13 nuts,I missed the 3 in the middle of the head.I removed them and the head came right off...There is a little bit of scoreing where I was using the screw drive but I don't think enough to bother any thing.....Albert
tennesseefarmer
09-17-2005 02:44:25
 Re: TO-20 Head Removal in reply to albert betts, 09-16-2005 11:49:19
Your an honest man albert, I would have never owned up to that.haha.
