oil slinger on TO-20
begray
09-20-2005 17:16:44
I recently purchased a Ferguson TO-20. I have worked on tractors before, but this is my first Ferguson. Working on the engine, I discovered the oil slinger on the front of the crankshaft is missing. Is this something I should replace, or do these engines do ok without it. I don't know how long this engine has been without it. It does have the Novi type (balls) governor. Anyone that has any experience with this, your help would be appreciated. Thanks.
John (UK)
09-21-2005 08:31:46
 Re: oil slinger on TO-20 in reply to begray, 09-20-2005 17:16:44
Well it is supposed to have the oil thrower, if it isn't leaking you could carry on with it till it causes problems. If you need to set up the governor I have the information, it doesn't operate any differently to the other governor with the weights.
fergusontractors at tiscali dot co dot uk
