TO-30 Hyd pump driven from front of crankshaft
Bearman
09-25-2005 20:36:02
I have a 1948 TO-30 with an after market bucket system which lifts on/off attaching to the rear axle and frame under the radiator. the hydraulics are powered by a pump mounted on the bucket framework. the pump is driven by a shaft that attaches to the vibration dampner. the shaft has four pins (studs) which appear to have been factory molded in rubber in the vibration dampner. where do I find this type shaft/ vibration dampner assy for my fergusion?
TM
09-27-2005 11:26:03
 Re: TO-30 Hyd pump driven from front of crankshaft in reply to Bearman, 09-25-2005 20:36:02
take the parts to a good machine shop and they can make the hub and shaft for you , i get them made up usually about 3 at a time so i have spares that last me for years, and they are cheaper than buying them from NH.
danct
09-26-2005 19:47:22
bearman
are you referring to the hub that mates with the front of the crankshaft,or the coupling assembly that connects the shaft to the pump,if you are referring to the later then i got one from a FORD NEW HOLLAND dealer ,they could still get it ,now remember mine was for a Wagner loader ,any thing else you might trythe SURPLUS CENTER in Lincoln Nebraska, 800-488-3407 they have a lot of surplus parts Danny
