TO35 Radiator antifreeze
Bob Weeks
10-03-2005 18:50:49
What type of antifreeze should I use in my TO20 and TO 35. I am almost ashamed to admit that I have had my TO20 for 33+ years and never changed the antifreeze. No leaks, no problems with water pump or radiator.
Gregg/Ohio
10-03-2005 21:53:44
 Re: TO35 Radiator antifreeze in reply to Bob Weeks, 10-03-2005 18:50:49
Mix 50/50 with distilled water,the plain old prestone (green) antifrezze, Never use anything red or anything called "Dex-Cool" ,as that is asking for major trouble. Good Luck,and please change coolant a little more often.
Bob Weeks
10-04-2005 09:54:40
 Re: TO35 Radiator antifreeze in reply to Gregg/Ohio, 10-03-2005 21:53:44
Hi Greg,
Thanks for the help. I tried lifting the front end of my TO35 to check the steering resistance and found that there seems to binding in the steering housing. I loosened the top housing cover and looked at the worm gear on the steering post it seemed well oiled and looked ok although the gears weren't pointed as I expected. At any rate, the tractor steers like a steam roller. and has a great deal of play from left to right before engaging. Can those gears, be polled out without removing the whole transmission cover?
I can't really use it the way it is.
