Fuel Tank
mikepa77
10-08-2005 21:13:31
Does anybody have any suggestions on how to repair a leak in the gas tank? (TO 35) Hairline crack, about an inch and a half long. The new tanks are expensive and I noticed some posts on this board in the past saying they didn't last long.
gshadel
10-10-2005 13:21:52
 Re: Fuel Tank in reply to mikepa77, 10-08-2005 21:13:31
JB Weld or similar epoxy will hold until you get a permanent fix. Need to clean the spot REAL GOOD to get oily residue off before using the epoxy. Heck, you might end-up just leaving the epoxy, if properly applied it will last a loong time.
george
Duner Wi
10-09-2005 10:55:22
Is there a spot weld near the crack? If so the baffle in the tank more than likely caused the crack and sealing alone may not be a permanent fix.
gerard
10-10-2005 11:14:01
 Re: Fuel Tank in reply to Duner Wi, 10-09-2005 10:55:22
Could have a patch soldered over it - but ONLY BY SOMEONE USED TO REPAIRING GAS TANKS. Don't want you to blow yourself up.
Dennis P in Ohio
10-09-2005 05:52:05
1. Have it steam cleaned , then brazed;
2. I believe on this site there is a compound for sale that you use to coat the inside of the tank to seal it. I've never tried it, but perhaps someone can comment on it.
Paul F B
10-09-2005 06:20:52
 Re: Fuel Tank in reply to Dennis P in Ohio, 10-09-2005 05:52:05
Yes; Por-15 is a rust preventitive that works real well. Kind of expensive but worth it in my estimation. Paul F B
