Shaft against the mower deck
Paul (FLA)
10-14-2005 13:14:19
I had the exact same problem. When I raised the mower all the way up, the shaft would bind against the front of the deck. This only would happen if I extended the top link, to take advantage of the draft control. I attributed the problem with my overrunning clutch. this clutch extends the PTO, thus moving the U Joint closer to the deck, thus causing less clearance for the deck and the shaft. I guess one solution would be to use an overrunning clutch that does not extend the PTO, OR shorten up the top link, and use limiter chains for height control.
Paul
Gene in La.
10-15-2005 21:58:24
 Re: Shaft against the mower deck in reply to Paul (FLA), 10-14-2005 13:14:19
Paul: I have the same problem when the hog is raised;(hitting the mower deck, I had to use an adapter for the pto shaft size to hog) I'll check the top lenght; could you explain the limiter chains for the low setting, because I look back and the hog will be cutting too low and I find myself adjusting up and down across the field, so you should see how the field looks!!! Thanks Gene in La.
