Ferguson autohotch
Melville Will
10-24-2005 16:33:40
Okay, I give up. What"s it for? Looks great though!
lonestarjeff
10-24-2005 17:05:55
 Re: Ferguson autohitch, explained in reply to Melville Will, 10-24-2005 16:33:40
third party image
I expected that response on the Ford N board!
But seriously, I'm not sure Harry had any made over here, I've only seen pictures in books & those sent to me by JohnUK & others on this board.
It has 2 purposes I know of, also called the "pick-up hitch" it allows the driver to drop the hook & back under the Ferguson 2-wheel trailer's pintle hitch & pick it up without getting off the tractor. The 2-wheel design of the trailer puts half the load on the tractor's rear wheels. The location of the hook(under the diffy)prevents the dreaded flip-over tendency of these little tractors.
The 2nd use of the hitch assembly is to pick-up weights on the T-bar without getting off the tractor. Used as counterweights on tractors w/ front loader. The ideal setup was to have a tractor w/ a FEL & a 2-wheel tipping trailer or manure spreader. You picked up the weights, use the FEL to load the trailer, drop the weights, back up to the trailer, pick it up & off you go. The tractor hydraulics power the trailer's hydraulic cylinder to dump the load.
You can remove all the linkage & leave the hook bolted up under the diffy, here's a pic:
Jeff
John (UK)
10-27-2005 05:40:22
 Re: Ferguson auto-hitch, explained in reply to lonestarjeff, 10-24-2005 17:05:55
There is also a conversion kit that allows you to have the Pick-up hitch fitted and be able to easily change over to the swinging drawbar too
lonestarjeff
10-27-2005 09:35:18
 Re: Ferguson auto-hitch, explained in reply to John (UK), 10-27-2005 05:40:22
Is that convesion kit what I saw in one of the pics you sent me yesterday? It was a bracket mounted to the tractor belly & the hook assembly was bolted under that.
Jeff
John (UK)
10-27-2005 12:01:45
 Re: Ferguson auto-hitch, explained in reply to lonestarjeff, 10-27-2005 09:35:18
Yes it sounds like it. Actually it is a flat plate, with a long pin through the front and the rear, the hook is fitted in a "U" shaped channel, open end down, with the hook inside, the top has two tubes welded to it to attach to the pins on the plate. The swinging drawbar is attached the same way, using the long pins.
Melville Will
10-25-2005 07:55:23
 Re: Ferguson autohitch, explained in reply to lonestarjeff, 10-24-2005 17:05:55
Impressive! Thanks for the response. You know, you could reverse that hook and land it on an aircraft carrier! I especially like that cupholder too!
lonestarjeff
10-25-2005 09:05:51
 Re: Ferguson autohitch, explained in reply to Melville Will, 10-25-2005 07:55:23
You know, I've heard of using a smog pump from an old Chevy big block engine to supercharge the N's flat-4 engine. If I ever do that it might be a good time to reverse that hook(grin).
Every good tractor needs a place to secure a beverage.
Jeff
