TO-30 CLUTCH RELEASE BEARING REMOVAL
Narman
10-29-2005 20:21:28
HI ALL, I need to know the easiest way to change the clutch release bearing, The replacement bearing is just a bearing not the whole assembly. Do I cut it off with a cutoff wheel? or is there a way to press it off?? Thanks in advance and thanks for advice on previous post. Narman
John (UK)
10-30-2005 10:38:29
 Re: TO-30 CLUTCH RELEASE BEARING REMOVAL in reply to Narman, 10-29-2005 20:21:28
Just press it off in a vise. Or support the bearing and tap the centre (the housing) out of the middle, be careful not to damage the housing when you do it this way.
