TO20 cracked steering gear housing !
BobW/tx
08-02-2000 13:25:18
I am seriously thinking of buying a very clean TO20 but the only serious flaw is an obvious crack in the side of the steering gear box. It appears the side opposite this crack has already been welded. Is this gearbox cast iron or ?, are replacements available or should I plan on finding a good welding shop? Is this a common problem ?
Thanks, Bob
BobW/tx
08-03-2000 17:35:21
 Re: Re: TO20 cracked steering gear housing ! in reply to rod, 08-03-2000 06:43:23
Thanks Rod, you were right, wengers has it in stock and it's really not too expensive.
I still wonder if this is a common occurance or just something that happened on this particular machine. I will investigate and see if I can see a reason for this to have happened.
Thanks again
BobW
