Hydraulic oil for my Ferguson
BobinKY
11-07-2005 19:05:51
I saw a post in here somewhere that said not to put regular tractor hydraulic fluid in my TO 35 Ferguson. What fluid should I use and where can I get it? I am restoring this old tractor and I drained the fluids. Thanks for your help.
Little Dave
11-09-2005 11:19:06
 Re: Hydraulic oil for my Ferguson in reply to BobinKY, 11-07-2005 19:05:51
I would never consider running any oil except GL-1 80 or 90W. The Multi grade paraffin base oil will not withstand the pressures imposed between the ring, pinion, and spider gears in the rear axle housing. Why mineral oil ? Dave
John (UK)
11-10-2005 10:22:34
 Re: Hydraulic oil for my Ferguson in reply to Little Dave, 11-09-2005 11:19:06
It is perfectly ok to use Multi-grade 15W-30 we had this out with Castrol oil.
Little Dave
11-10-2005 19:17:58
 Re: Hydraulic oil for my Ferguson in reply to John (UK), 11-10-2005 10:22:34
Then use it in your tractor ..... .. if you own one
John (UK)
11-09-2005 09:53:44
The original spec for the oil was GL1 90W which is a straight mineral oil but you can use a Multi-grade oil 15W-30 which is good if you have a cold winter climate as it doesn't get as thick as 90W when cold. It stays more fluid over the whole temperature range. You should be able to get this from any oil supplier.
Jerry/MT
11-08-2005 10:41:34
The older Fergusons specified GL-1 mineral oil for the trans/hydraulic fluid;90W for summer and 80W for winter. You can find this at NAPA.
I believe MF says you can use MF 1129 or 1130 spec oil also. DO NOT PUT IN REAR AXLE GEAR OIL!
marlowe
11-08-2005 15:01:59
 Re: Hydraulic oil for my Ferguson in reply to Jerry/MT , 11-08-2005 10:41:34
the only reason the MF dealers say you can use 1129 or 1130 is that they don't know any better use M1103 ONLY or napa oil of GL-1 rating minneral oil
George in Spokane
11-11-2005 14:16:59
 Re: Hydraulic oil for my Ferguson in reply to marlowe, 11-08-2005 15:01:59
John, are you saying we can use 15W-30 for gear oil? If you think it's OK then that's good enough for me.
I have trouble finding the staight stuff.
