TEA 20 Waterpump.
Bill Brox
11-09-2005 12:27:24
Hi, got my waterpump in pieces today, and discovered the old and the new pump are not equal, the new one is much longer. So, I either need to get a new bearing and seal for the old one, or a new hub and pulley for the new one... but will it fit then... ? Anyone who have been there done that ?
Bill
John (UK)
11-09-2005 13:28:20
 Re: TEA 20 Waterpump. in reply to Bill Brox, 11-09-2005 12:27:24
You are busy today Bill.
there are 2 different pumps and 3 different seals for the original types. Depends on who made your new Pump as to what parts you can get but usually you can convert to the new type.
Jim W
11-10-2005 08:02:18
 Re: TEA 20 Waterpump. in reply to John (UK), 11-09-2005 13:28:20
The bearings are no longer available for the original pump, which could be why they came out with a different one as a replacement. It seems very odd that bearings, which are pretty standardized, would not be available, but I have searched, as have many others - to no avail. (They are the same in the old Triumph cars with the similar engines, so lots of people would like them.)
Jim
John (UK)
11-10-2005 10:12:05
 Re: TEA 20 Waterpump. in reply to Jim W, 11-10-2005 08:02:18
Jim, Can you remember what the bearing number was and do you mean the type that had one long bearing in the middle of the pump shaft.
Jim W
11-15-2005 12:44:41
 Re: TEA 20 Waterpump. in reply to John (UK), 11-10-2005 10:12:05
No, I have the pumps with two bearings, one at each end of the shaft. It is the same bearing that is used as the pilot for the input shaft in the transmission (that sits in the centre of the flywheel).
Part # is 825-375 M1.
Jim
Bill Brox
11-10-2005 10:37:04
My old pump has the long bearing, I got one today, but I have to make a sleeve on the impeller end because it is only half inch thick and not five eight of an inch thick as it should be. And, I will also have to cut the axle a little too.
Bill
John (UK)
11-10-2005 11:57:15
 Re: TEA 20 Waterpump. in reply to Bill Brox, 11-10-2005 10:37:04
Interesting Bill, that bearing is supposed to be n/l/a....can you let me have the make and part number of it please. That must be the original water Pump on your tractor then....not bad for 60 years is it. No you can't claim it under warranty.
Bill Brox
11-10-2005 12:32:54
 Re: TEA 20 Waterpump. in reply to John (UK), 11-10-2005 11:57:15
Excuse me Sir, may I be enlightened in what n/l/a is ? :-)
Bill
John (UK)
11-10-2005 12:51:44
 Re: TEA 20 Waterpump. in reply to Bill Brox, 11-10-2005 12:32:54
oopps sorry Bill....n/l/a means...no longer available.
Bill Brox
11-10-2005 12:57:58
 Re: TEA 20 Waterpump. in reply to John (UK), 11-10-2005 12:51:44
Well, the one I got is also not longer available. Besides, it is not the right type either so I will have to modify it.
It lays at my work, so I can not give you any number tonight, but I think it is a FAG bearing.
