injector pump
okiejones
11-19-2005 08:12:28
rebuilt a 59 to 35 with a 23c new crank and bearings, pistons sleves and valves runs good smokes white a little, it doesnt seem to have the power it did even with a cracked piston. if i advance or retard the injector pump timing will that give me more power? if so what is the correct way to do this.
thanks for any advice
gerard
11-19-2005 12:35:12
 Re: injector pump in reply to okiejones, 11-19-2005 08:12:28
Timing needs to be as per specification - not advanced or retarded. White smoke could be either. Lack of power suggests retarded. If engine isn"t "noisier" than it used to be, slacken & rotate pump to advance. Of course, you may be a full tooth out.
