Grey Fergie Diesel Pump Leak
Aussie Steve
11-19-2005 23:56:04
I have a fuel leak on the diesel pump...seems to be from the side plate on the motor side of the pump. How hard is it to get the pump off to repair the gasket? Any special tools needed?
John (UK)
11-20-2005 05:00:44
 Re: Grey Fergie Diesel Pump Leak in reply to Aussie Steve, 11-19-2005 23:56:04
Hi Steve, No special tools necessary, if your engine number is after SA5222E it has a directional drive coupling so you can remove it safely and easily without worrying about the timing, it will only go back one way and it will drop into place when you turn the engine over after re-fitting the pump, just make sure that you scribe a mark across the flange between the pump and the timing cover so that you can refit the pump in exactly the same position as it was before. The engine number is stamped into the block just above the generator. If you have any more queries about this, please mail again...John
Aussie Steve
11-26-2005 20:07:40
 Re: Grey Fergie Diesel Pump Leak in reply to John (UK), 11-20-2005 05:00:44
Thanks John.Your advice spot on. Job done, leak fixed. Cheers
