TO20 Starter
Bencar
11-21-2005 17:49:03
I have a broke starter on a 1951 TO-20 coverted to 12 volt. Is the starter original or does conversion change it?
jerrycpp
11-22-2005 05:49:58
 Re: TO20 Starter in reply to Bencar, 11-21-2005 17:49:03
More than likely the starter is original. One of the advantages of changing to 12 volt is the 6 volt starter turns twice as fast on 12 volts. The most common cause of broken starters is not letting the starter completely stop before trying another start, or trying another start while the engine is kicking back.
John (UK)
11-22-2005 08:28:32
 Re: TO20 Starter in reply to jerrycpp, 11-22-2005 05:49:58
We have had a few of these over the last months and most seem to say check ignition timing.
Model....Point Gap/Spark Plug Gap
TO-20,.....020"..... ...025"
Timing Mark On FLY 6 deg BTDC I hope that cures your problem. If not post again.
