How to adjust clutch on 860 Ford, 800 series
Andrea Hodge
12-12-2005 12:21:23
I need to know how to adjust clutch on 800 series, 860 Ford,Gas 5 speed transmission, and is there a seal that can be blown. Because am getting water in tranmission and hydraulics?
phil(va)
12-13-2005 05:39:34
 Re: How to adjust clutch on 860 Ford, 800 series in reply to Andrea Hodge, 12-12-2005 12:21:23
As for clutch adjustment, probably best to post your question on the Ford Board. However, I can tell you water often enters the tranny via the rubber seal at the bottom of the gear shift lever if the tractor is outside in the rain. Those seals get old and crack and leak. New seals for the gear lever are available from most all the reputable mail order houses and New Holland dealers.
