My TEA 20.
Bill Brox
12-12-2005 13:03:40
Hi gang... :-)
I have come so far with my TEA 20 restoring that I was about to empty the engine sump for oil, to put the plug back and clean the underside of the engine so I could put primer on that too.
Bummer, grey and with water. I guess the solution is to disassemble the entire engine and put in some new stuff.
How about new pistons and liners, and bearings and so ?
Bill
gerard
12-12-2005 14:19:08
 Re: My TEA 20. in reply to Bill Brox, 12-12-2005 13:03:40
Whether you need liners, etc will obviously depend on wear when you measure it.
In the meantime, I always recommend in cases like this to drop the sump pan with everything else in place & pressure the cooling system. That way, you can see where the leak is coming from. Could be headgasket, or perhaps the gaskets below the liners in need of replacement.
