coil
Albee
12-12-2005 16:38:49
I have a 1953 TO-30 I need to replace the coil it has been converted to 12 volt What coil should I use?
Albee
12-13-2005 16:43:58
 Re: coil in reply to Albee, 12-12-2005 16:38:49
What I should have ask for was a part number The olms and so forth are greek to me thanks for your help
Dell (WA)
12-14-2005 07:14:32
 Re: coil in reply to Albee, 12-13-2005 16:43:58
Albee..... ...I recommend the roundcan NAPA IC-14SB real 12v ignition coil that uses NO RESISTORS for 12v convertions. $15 (cheap)..... ...Dell
buickanddeere
12-12-2005 18:51:16
3.0 ohm primary winding coil, 12V. Or a 1.5 ohm, 6V coil with a ballast resisitor in series for use on 12V.
