TO35 Steering Housing
Bob Weeks
01-06-2006 16:37:07
I recently replaced the steering shaft, ball block bearing and other roller bearings in my 1955 TO35. I am ready to put it back together but can't find any information about what kind of lubricant or how much to put back in the reservoir. All I have is an I&T Shop Manual. It doesn,t give much information. The reservoir seemed to be about half full when I removed the shaft and bearings. Can anyone help?
FergieFlyer
01-06-2006 19:45:14
 Re: TO35 Steering Housing in reply to Bob Weeks, 01-06-2006 16:37:07
Bob - The following paragragh is from my 1955 TO-35 owners manual..."The steering assembly has a capacity of 2 U.S. pints transmission oil. If the oil is low, add transmission oil. Normally, the oil will not require changing; however, if necessary, the steering housing will have to be removed from the tractor and drained." That"s all I could find. Mike
Bob Weeks
01-06-2006 20:01:29
 Re: TO35 Steering Housing in reply to FergieFlyer, 01-06-2006 19:45:14
Thanks for the speedy response. This is such a great forum. I knew I could count on someone for an answer.
Grateful in Horton, MI
