sherman overdrive unit
bill nelson
01-11-2006 05:37:28
I've gone thru all 12 pages of forum and can't find anyone one wanting imfo on O.D. units. I have one to put in a TO-30 and would like imfo on if it is OK and if I can get parts ( seals- bearings - part Etc. ) and what web site to get them from. The main shaft seems loose and I know it is a sealed unit. Can someone HELP !
Donald Daugherty
03-18-2007 08:57:35
 Re: sherman overdrive unit in reply to bill nelson, 01-11-2006 05:37:28
I recently installed a Ford Sherman step up unit into a TO 30. Had to make some modifications to transmission case. Also I made some changes to clutch cross shaft. Had no problem with the starter linkage. It really wasn't that much extra work
Mike Mohrhauser
01-13-2006 09:18:42
Bill,
I told Paul about your Sherman endevor. He would like to have some photos and an account of it to put in the Furrows.
Mike M.
1466max'd
01-11-2006 10:46:57
we have one in my dads old TO-30 been in there sience he got the tractor in the late 70"s and never gave a bit of trouble... been through 3 engines 1st one bad oil presure and last two been cracked blocks.. geting ready to totaly re do the tractor and looking like the only option is to measure the seals and bearings then go to a specialty store to look them up..
Jim in OH
01-11-2006 07:44:46
third party image
Did you checkout John Smith's site?... He doesn't advertise that he sells parts, but I know he can get them because he rebuilds and sells Sherman Transmissions... You may want to contact him. His link is below...
Also, just as a matter of interest, Sherman "combo" transmissions that were made for the Ford and not specifically for the Ferguson will have interference with the gearshift starter linkage. You will have to either give up this feature or provide another work around solution... The picture above shows the factory differences between the Ford parts (on the left) and the Ferguson parts (on the right) that was made to preserve this feature...I don't know if this was the same issue for the step-up transmissions.. and I know that there have been plenty of the Ford versions that have been adapted to the Fergusons.... usually by giving up the gearshift start feature.... Jim
bill nelson
01-12-2006 05:44:40
 Re: sherman overdrive unit in reply to Jim in OH, 01-11-2006 07:44:46
Jim in OH or any one else know if a cable type OD unit will interfere with the start shifter? I have the web site for my OD unit. If you have one of this type in your fergy can you leave me a message Link
Thanks>Link
bill nelson
01-11-2006 17:40:07
Thanks to all for the replies. I don't feel quite so nervous about my purchase of the OD unit now! The smith web page helped alot. As to the difference in the unit from fergy / to 8n I'm not sure yet. still hoping for a shiny TO-30 in the spring that's fast!!!!! THANKS AGAIN
gerard
01-11-2006 06:01:34
I put "sherman overdrive" in the search at top of page, & 12 articles came up - don"t know if any will help though.
