TO-20 swinging drawbar
Bernie Poeppelm
01-21-2006 10:41:21
How do I bolt up a swinging drawbar under the rear end? Do I need to buy studs? Do I tap out the holes? Thanks for any help
Bernie Poeppelman
01-23-2006 15:21:34
 Re: TO-20 swinging drawbar in reply to Bernie Poeppelman, 01-21-2006 10:41:21
You guys surely know your stuff. I borrowed a 5/8" X 11 tap and cleaned the junk right out of the holes. It was a piece of cake to bolt my swinging drawbar plate on after that. I really appreciate the advice.
John (UK)
01-22-2006 11:53:58
There are four tapped holes already there 5/8"unc they may have the blanking off screws in them though. You will need studs and usually they come with the drawbar if it is new. The tractor is tapped 5/8"unc and the drawbar end is 5/8" unf
marlowe
01-21-2006 13:16:50
i have 5 to-20s and they are all taped from factory if yours arn't that would be strange. should be 4 holes
