year and model
niagara region
01-24-2006 18:49:12
I have a ferguson with a missing serial # plate the engine numer that is stamped on block between oil filler and coil is ( S109524E )and 85 cast in the block.also found casting #s by carb (56238) and (DA 19316) any help would be great thanks
niagara region
01-25-2006 18:23:34
 Re: year and model in reply to niagara region, 01-24-2006 18:49:12
answer to jeffs question. The oil filler is located at rear of engine and shifter plate is part of steering column .thanks john and jeff for your help
John (UK)
01-25-2006 11:47:30
That engine number is from 1951 and it looks like an 80mm serial number but having that 85 cast in the block is odd.
Jeff-oh
01-25-2006 05:23:04
It sounds like you haave a TEA-20 Ferguson.
To verify,
Is the cover plate that the gear shift goes through part of the steering column, or seperate?
Also, where is the engine oil fill, at the front or back of the engine?
Jeff
