Flatbar Hitch
Utah Jim
01-30-2006 06:09:34
Is there a hitch assembly that bolts on under the PTO on a TO20? Would it be heavy enough for Tractor pulling?
Thanks Utah Jim
Utah Jim
01-30-2006 17:36:52
 Re: Flatbar Hitch in reply to Utah Jim, 01-30-2006 06:09:34
Thanks Jim in OH. and George in MI. I really appreciate your responces and pictures. I'll do some calling around to try to find one.
Thanks Utah Jim
Utah Jim
01-30-2006 17:28:22
Thanks Jim in OH. and George in MI. I really appreciate the responces and pictures. I will call around and see what I can find. Your info was very helpful.
Thanks
Utah Jim
Jim in OH
01-30-2006 08:22:51
Yes and Yes... Available many places... search for "swinging drawbar"... but..
Issues concerning tractor pulling:
Length: Depending upon your class/rules, allowable length might be as short as 18" (from the axle centerline) or as long as 24". YOu may have to drill holes in drawbar to shorten and/or add length to get the optimum length.
Height: Height might not be optimum without having the drawbar modified (bent up) or make a new one. Heights are usually 16", 18" or 20" max. from the ground depending upon rules. Again, might need drawbar mods to get optimum.
Flexibility: If you ever get serious about pulling, then flexibility will be an issue. The aftermarket drawbar will flex downward somewhat decreasing the hitch height... YOu can make a new one thicker and wider ...
If you are pulling in divisions/clubs that allow custom pulling hitches, they are made rigid and adjustable.... often with turnbuckle-like adjusters...
Ocasionally there is a club/class that will allow only "stock" hitches (meaning what was available from the factory), in which case there is not much available... just the long swinging (rolling/sliding)drawbar over the long 9/11 hole bar in the lift arms... unless you can find a funky old (rare) original (see below).. there were many types of aftermarket hitches sold for this tractor, even Sears had one...
third party image
Ford/Ferguson swinging drawbar
third party image
Same thing
third party image
Sears hitch
third party image
An old Ferguson original...
Good luck..
Jim
George in MI
01-30-2006 06:26:38
 I have one in reply to Utah Jim, 01-30-2006 06:09:34
I have a flat hitch on my TO-20 that bolts on the bottom. I don't know whether this would be suitable for tractor pulling. It seems to me that it should but we'd better get a more knowledgeable answer.
