HELP TO-30 with a motivation problem
Farmer Y
08-28-2000 13:45:30
I need a cheap solution to a grave problem... my TO-30 Dropped a valve, destroyed the piston and head. Upon inspection, the tractor has had a tree dropped on it in the past (and I'm not exaggerating!) where the crank was bent when the tractor broke clean in half at the bell housing (which by the was was welded together. What I need to know is: 1. Is there a cheap solution to fix it? 2. Are there any other engines, or the same engine in some common piece of farm equipment which might fit with light-to- moderate modification? 3. I've considered putting a 4 cyl S-10 chevy engine in it (like the older 8N V-8 transplants) any info on that?
Much Appreciated .... Farmer.
