Ferguson Model/year
craig /oh
01-31-2006 12:23:16
I would like to know what model and year my new tractor is.It has a three speed with high and low range,two stage clutch,no id tag,MHF prefix on all castings,D.30.7. stamped on left hand side of transmisson,Z134A500P on engine,hood has lid for refueling and also hinges foward,exhaust is vertical.
Paul in AZ
02-01-2006 05:01:31
 Re: Ferguson Model/year in reply to craig /oh, 01-31-2006 12:23:16
I agree that you most likely have a TO-35. You should be able to read the number on the engine SN plate since it was stamped in. However, when removing the grease and grime do not use sandpaper or steel wool or a steel brush as you may damage the metal plate. Once you post the engine SN from that plate, it will be possible to find out the exact date the engine was built and shipped to the Ferguson factory. That will give you a clue as to the year the tractor was probably built.
Mike Mohrhauser
01-31-2006 17:59:32
What color is it? Is it the original color? Can you post a picture or two of it? The TO35 Ferguson was made as early as 1954 which has these features. The MF35 also has a Z134 engine. I have one that is a 1961. I'm not sure when they quit producing the MF35 and changed to the 135. At any rate, you have a well designed tractor.
Mike M.
Jeff-oh
01-31-2006 14:13:50
The origional tractor data plat would be on the dash. Where are you in Ohio? I am in SW.
Jeff
craig/oh
02-01-2006 04:27:50
 Re: Ferguson Model/year in reply to Jeff-oh, 01-31-2006 14:13:50
The hood/grill/dash have all been replaced. It has no emblems lights or decals left on it. There is no data plate as well. There is the Ferguson emblem on the front of the hood but it has been painted over.
J2
01-31-2006 13:15:15
Need more info.. TO-35, MF-35, F-40, MF-50, ??
Jerry/MT
01-31-2006 12:37:38
The Continental Z134 was used on the TO-35 and the f40. That engine number sounds like a casting number. Look at the data plate on the engine 's left side just below the head in the middle of the block for a serial number. This can sometimes give you an idea of the year. I'm guessing that you have a TO-35 Deluxe because of the 2 stage clutch but there are people more knowledgeable than I about that.
craig /oh
02-01-2006 04:33:10
 Re: Ferguson Model/year in reply to Jerry/MT, 01-31-2006 12:37:38
I will take the engine id tag off and try to save it maybe I can get the #'s from it but it looks like fifty or sixty years of grease/paint, paint grease ect. Not sure if I will be able to salvage it.
