Jaking up the TE20...
Aikidoforever
02-01-2006 15:54:58
Hello again everyone,
I need to jack up my tractor to do some work on the Right Rear axle. Any info as to where I should mount the Jack? I don't want to damage anything, so I'm just being cautious.
Thanks,
Ivan
jason wills
02-01-2006 17:25:54
 Re: Jaking up the TE20... in reply to Aikidoforever, 02-01-2006 15:54:58
I have put ajack right under the axle never had no problem.
Bill Brox
02-03-2006 09:00:08
 Re: Jaking up the TE20... in reply to jason wills, 02-01-2006 17:25:54
Hi, well, if you are going to remove the right rear axle housing you can not put the jack under there... but then you can put the jack under the middle between the axle housings... under the differential.
Remember to lock the front axle with some wood blocks so the tractor does not tip over if you take the axle housing off.
Bill
Aikidoforever
02-03-2006 10:45:57
 Re: Jaking up the TE20... in reply to Bill Brox, 02-03-2006 09:00:08
Thanks to both of you for the info. Always nice to get a little input on this sort of stuff when you are pretty much a novice "tractor mechanic". ;-) Thanks again guys.
Ivan
