Howard aux. in a Ford? (from to30) Attn: JohnUK
gpogpo
02-02-2006 17:47:35
Jeff on the Ford forum suggested that John UK on this forum might know if you can take a Howard out of a TO30 and pop it in an 8N. Anyone know?
jimNCal
02-03-2006 20:09:01
 Re: Howard aux. in a Ford? (from to30) Attn: John in reply to gpogpo, 02-02-2006 17:47:35
If the Howard is the one between 2 smaller plates that requires drilling and tapping the back of the tranny to mount it, the only hang-up I can suggest is if the female/female coupling is different. If so, cut the old Fergie & 8N couplings in half and reweld the ends so you end up with the proper ends/length. HTH jim
ps..... you DO know NOT to use your Howard for a 'pulling' gear, right. No offense intended but, they are too rare and irrepairable to 'learn the hard way'. j
gpogpo
02-03-2006 22:08:29
 Re: Howard aux. in a Ford? (from to30) Attn: John in reply to jimNCal, 02-03-2006 20:09:01
Nope, just want to slow it down to blow a little snow.....and maybe run a rototiller. Thanks for the info!
jimNCal
02-03-2006 23:03:26
 Re: Howard aux. in a Ford? (from to30) Attn: John in reply to gpogpo, 02-03-2006 22:08:29
Good plan. Just what they were designed for. Best of luck and tractor safe....jim
