1951 TE 20 ferguson
bob.mcle
02-17-2006 15:28:34
I have a rear wheel seal leaking. What is needed to repair this and how do you get the bearing and housing off the axle. Where can i get the seal.
John (UK)
02-18-2006 11:36:50
 Re: 1951 TE 20 ferguson in reply to bob.mcle, 02-17-2006 15:28:34
Well it wont be a 1951 TE20 as they stopped making them in 1948 it will be most likely a TEA20, the axle is the same. Providing the bearing on the axle shaft is good you can do a quick repair by using "Sure Seals" these slip over the end of the axle shaft without any dismantling of the shaft; and then go into the end of the trumpet housing, the lip of the "Sure Seal" runs on the bearing collar on the shaft. You don't say where you are so we cant advise you where to go most tractor dealers will be able to get them from SPAREX under part number S61512
