Love my TO-30
Paul (FLA)
02-27-2006 08:18:50
I worked her real hard yesterday. Was towing a loaded trailer up a small hill with mud. I was using first gear, and she was heavy on the rear wheels. In your opinion, where is the weakest link in the drive train? If I dont stall the engine and the tires don't lose traction, what will give first: clutch? gears? 3 point?
I am amazed at the power in first gear.
Paul (FLA)
J2
02-27-2006 10:20:09
 Re: Love my TO-30 in reply to Paul (FLA), 02-27-2006 08:18:50
If I don’t stall the engine and the tires don't lose traction, what will give first: clutch? gears? 3 point? I am amazed at the power in first gear.
Assuming all components are in factory new condition (which they are not):
1- On level ground (nominal factory weight and distribution) without a 3pt implement, proper hitching, it will lose traction first. On a hill, or with lifted implements, or with the wrong hitching, the front end will lift. Also, with improper hitching (or on a hill), it can tip over. 2- Then assuming that you add weight (load tires, etc.) to keep traction (and this assumes you add it in such a way as to keep the front down, which is not trivial with a short, light, tractor), you’ll then stall the engine before you break something. However, if your clutch in not up to par, then you might slip the clutch first. 3-Swap engines/add nitrous/supercharger/etc. (and clutches) to about 70+ hp or so, add Sherman reduction unit, more weight, then second gear in the transmission is probably the weakest link, but in first gear, all other components (gears, cases, bearings, shafts, axles) are then about equally susceptable to breaking.
4-You are not likely to overpower the 3pt
J2
Paul (FLA)
02-28-2006 10:54:50
 Re: Love my TO-30 in reply to J2, 02-27-2006 10:20:09
Thanks J2
I was not lifting the front, although I do have a bucket. I guess you are saying that, this machine was designed with properly matched mechanics, so the engine power would not be able to break a component. (Assuming of course a component is not failing due to age)
thanks again
Paul
