TO-20 Rear axle seals
Bad Habit
09-08-2000 19:28:54
When pulling rear axle do you have locks in the rear end or can you pull the axle straight out?
Please help. I'm trying to replace seals in the axle.
Bill Mc
09-08-2000 20:56:39
 Re: TO-20 Rear axle seals in reply to Bad Habit, 09-08-2000 19:28:54
Unbolt from the axle housing and pull straight out,no locks in the rear end. The TO20 has only outside seals. You can buy a seal called a sure seal for the inside (do not have to remove the collar and bearing to install the sure seal).Read the archives for more info.Good luck
Bill Mc
