Hood for my TO35
BobinKY
03-16-2006 13:21:09
I just bought a hood, doglegs, grill and bottom cross support for my TO35 off of Ebay. It was represented as a hood for a TO35 but when I put it together and tried to shut the hood, it hit my radiator and held the back of the hood about 1 1/2" short of closing. When I took a closer look, it appears that the front of the two hoods are somewhat different. The original TO35 has a dish cut out of the front where it fits around the top of the radiator. The new hood has a flat bar which hits the radiator tank. Could this be a hood for a TO 20 or smaller tractor? Other than this, I think this hood will fit after I get done "tweaking" on it.
scott morrow
03-16-2006 15:19:43
 Re: Hood for my TO35 in reply to BobinKY, 03-16-2006 13:21:09
Bob I saw the hood you bought it is off of a early to35 your must be a later massey 35 the difference in these hoods are the dog legs or side panel the mounting holes are lower in the leg making the hood ride higher this made more room when the disel engine was used. switch the dog legs with your old ones and it should fit. Scott the ferguson nut
