Ferguson TEA 30 hydraulics
Alex
09-17-2000 03:46:31
What's the most likely cause of inoperative hydraulics, which were previously OK, on a tractor which has been idle for a couple of years?
TAFFY
09-18-2000 14:28:55
 Re: Ferguson TEA 30 hydraulics in reply to Alex, 09-17-2000 03:46:31
I've repaired a number hydraulic faults on T20 tractors here in Wales, UK, and the most common causes I've found are:
-broken or bent control valve -poor quality oil
-lots of muck preventing control valve operating correctly.
-stuck piston under hydraulic cover. hope this helps.
JOE FERGUSON
09-18-2000 03:37:11
Hi Alex
Be sure that the PTO is engaged because the hyd pump is driven by PTO shaft
And...start the engine PTO engaged and let the
whole thing warming up...may be some air in hyd system runing for a while may bring you good
news.
Good luck
Joe Ferguson
rod
09-17-2000 08:56:34
something could be stuck in the controls, or a pin may have dropped out you almost have to take it apart to find out just drain oil out and remove two side covers take out small pins in fork assembly on each side thsi has to fit back together or it will not work. Let us know if you get it apart you must take off top cover after you get the fork apart. regards
rod
English Please
09-17-2000 13:26:54
 Re: Re: Ferguson TEA 30 hydraulics in reply to rod, 09-17-2000 08:56:34
Yikes, that was tough to read!
