Hydraulic Loader Oil Question?
Tim in Tenn.
03-27-2006 18:23:52
I have a John Deere No.30 Loader on a TO-20. it has a front pump that drives off the engine and it's own control valve and reservoir. The book for it says to use 10wt motor oil. I can't find 10wt oil. What can I use?
souNdguy
03-29-2006 07:17:18
 Re: Hydraulic Loader Oil Question? in reply to Tim in Tenn., 03-27-2006 18:23:52
That closed system should be very forgiving.. i imagaine everything from UTF to ATF/ power steering fluid, to aw32/46 would work.. etc.
Soundguy
Jerry/MT
03-28-2006 13:17:34
Usually you can use AW 46 hydraulic fluid in these systems since they are separate from the tractor hydraulics.
toolman
03-27-2006 21:47:26
i have a simialr setup though not JD, i have always used ATF , since 87 an never any problems.
