compression numbers
BobH1640
04-04-2006 18:31:16
Does anybody have the compression numbers for a TO20?? There is nothing in the maintance book on how to test and what the numbers should be, either wet or dry. I used my compression guage and got 110 lbs on all four but I would like to know where they are on the scale??? It is a 51, TO20.
gshadel
04-05-2006 04:37:10
 Re: compression numbers in reply to BobH1640, 04-04-2006 18:31:16
Those are pretty good numbers Bob.
I was getting 60 - 90 psi when I decided to rebuild my TO-20. I tried testing my compression after the rebuild, I was getting ~120-130 psi, but I also had trouble holding-on to my compression gauge and getting good numbers.
George
phil(va)
04-04-2006 19:29:25
Main thing is not to have too much variation. 110 lbs is good. And it is even better that you got that reading on all four cylinders.
