Ferguson Lift Arms
Kevin South Afr
04-10-2006 08:08:05
The lift arms on my Ferguson are not lifting the implements.
Without load they lift after a time .
What could I be doing wrong ?
Or what could be wrong with the Tractor ?
John (UK)
04-10-2006 08:25:26
 Re: Ferguson Lift Arms in reply to Kevin South Africa, 04-10-2006 08:08:05
Have you checked the oil level? have you got the correct grade of oil in there, it should be Multi-grade 15W-30 or GL1 90w, no other type is suitable. It may be Control Valve stuck, quite a number of things actually. I will write separately to you about this.
