tea20 Hydraulic control lever mount.
BobSymons
04-25-2006 18:50:24
The whole hydraulic lever mount came loose. I would like to know if it should be welded to the bolt on bracket that fits on the housing.
John (UK)
04-26-2006 11:01:30
 Re: tea20 Hydraulic control lever mount. in reply to BobSymons, 04-25-2006 18:50:24
Not too sure what you mean but I will have a go. The part that actually bolts to the tractor IS welded to the Quadrant part (the part with the lever in it) But the quadrant needs to be reset when it is fitted back on the tractor again. Put a mark on the quadrant 2-1.2" from the top of the slot, the hydraulics should start to drop as the lever passes this mark. Move the quadrant on the slotted fixing until you get it right. If you need anymore info in this email me at:-
fergusontractors(at)tiscali.co.uk
