Front Wheel Bearings
BoCoMO
04-29-2006 08:43:27
I have a MF135 and a Ferguson TO-20. I have noticed a problem with the large bearing in the rear of the front wheel hub that fits against the base of the spindle pin. On both these tractors, this large bearing starts spinning on the spindle pin so that it wears into the base of the spindle pin. Eventually it wears to the point where the hub starts to contact the spindle and wears down the hub to the point where the bearing seal is being contacted and worn away. Has anyone seen this problem and corrected it. Do you glue or wedge the rear bearing so it can not spin on the spindle? I want to know what others have done.
John (UK)
04-29-2006 10:16:09
 Re: Front Wheel Bearings in reply to BoCoMO, 04-29-2006 08:43:27
Sparex do bearing kits for these hubs part # S02970 for the TE/TO20 up to early 35"s amd kit S02974 for 35"s 36815 and on. You can get them from this site or order from your local tractor dealer. 1 kit per wheel.
mark from the fort
04-29-2006 09:02:26
I believe that the race (the cone in the rim in which the bearing rides on)-and in your case might be wore out-can be knocked out and replace with a fresh one-this should seat your bearing at a distance to which when assembled, will keep the rim (and dirt seal) away from front spindle.
I think kits are available which include both bearings, dust seals, and new race's/
Please wait for other repsonses to verify remarks. Thanks Mark.
