Hey RustyVT Wagner Loader FordWM3 what's it fit?
Eric Stevens
05-16-2006 04:05:59
Ok Rusty..sorry it took so long...I found a tag on the loader that I didn't know was there. It says "Wagner Iron Works" Mod. # FORDWM3 Serial #12199 and a tag on the bucket that is nearly all worn away but could make out two numbers on bottom left of the bucket tag it says W3 2003 and on the bottom right of the tag it says 4158. That is all that shows up. Length from rear brackets (very outter measurement) is 86-87", the width at the front is 25" inside with the hydraulic line being on the inside of that but could be moved, inside near the rear brackets at the pipes is 27" and center line of the rear brackets is 35.5"(plus or minus .25") it was raining and I was hurrying..outer measurements of the rear brackets is 44.25"..Can you help with what this fits? Eric....ews10@hotmail.com
