what fergusen do i have ???
aaalex
05-17-2006 02:29:40
it is 4cylander petrol; serial# plate is totally corroded <<
br>br>away; engine number reads _S63282E ( there may be another character before the "s" but it has been rubbed away by ignition coil"s bracket); the ferguson tag on the side of the main engine cover only has "ferguson" in
cursive-type/hand writing ( no space for any model
number).we are located just above Sydney, Australia.
we would like to get this tractor up and running ; need basic info so we can get correct parts etc many thanks.
PTF
05-20-2006 13:54:56
 Re: what fergusen do i have ??? in reply to aaalex, 05-17-2006 02:29:40
When I bought my tractor I was told it was a Ferguson 2085. I don't see much reference to a 2085, maybe they are also known as something else. The serial number from the steering column starts with a permanent TE followed by a stamped A442066. Can anyone identify this tractor? It seems to have a botched 12 volt conversion whereas the battery appears to overcharge and is dead the next time I use it. I need to correct this charging system pronto...she just died on me while bushhoggin'. Thank you
John (UK)
05-17-2006 04:01:04
You have either a TEA20 (petrol) or a TED20 (TVO)
PTF
05-20-2006 22:30:02
 Re: what fergusen do i have ??? in reply to John (UK), 05-17-2006 04:01:04
Thank you John. I'm just knew at using a forum. I also posted the same question under it's own heading and got several other responses. Sorry for the duplication.
John (UK)
05-21-2006 04:20:39
 Re: what fergusen do i have ??? in reply to PTF, 05-20-2006 22:30:02
We all had to learn sometime....just keep trying it you will get the hang of it.....John
