Control box on a FE35 Voltages
Jon
10-01-2000 18:34:56
I have a FE35 with a Standard Motor Company Diesel engine. The control box is a Lucas RB108 (not the one in my manual). I have done the test that the manual suggests ie. start the tractor, take on of the leads off the battery and measure the voltages increasing the throttle as you go.
I watched as the voltage went in excess of 20 volts and then dropped to a constant 19.5 volts when the control box kicked in.
My question is, isn't 19.5 volts a little high to charge a 12v battery? I would be expecting to see 13.8 or there abouts on my car. I know that car batteries are different from tractor batteries but that is a big difference.
Is my control box due for replacement? (I guess that it is over 40 years old!)
Marshall
10-23-2000 19:12:01
 Re: Control box on a FE35 Voltages in reply to Jon, 10-01-2000 18:34:56
I have a Allis Chalmers DE40 with the Standerd Ricardo 4cyl. disel engine and I would like to overhaul it, do you know where I can find parts.
Gubra
10-02-2000 02:50:50
Hi Jon.
The voltage should be around 14 volts. If you live in a mild climate it's ok with 13,8V, in cold climate it should be around 14,2V.
20 volts is way to high. It will kill your battery .
Regards
Gubra
Jon
10-02-2000 13:35:13
 Re: Re: Control box on a FE35 Voltages in reply to Gubra, 10-02-2000 02:50:50
Thanks Gubra, forgot to mention that I am in Australia, we do have a mild climate.
Does anyone want to comment on the Lucas RB108? Have I got the wrong box? Should I just ask my tractor spare parts man for a replacement box?
