TEA20 hydraulics-HELP-
Bob
10-03-2000 17:18:31
I have a TEA 20 that I am not sure that the fork assembly is working properly. The control lever appeared not to touch the fork assembly although the fork assembly appears to be working. Is the top arm above the link to pivot seperately of the lower portion of the fork assembly? Would like to talk to someone by phone that knows how this system works. If you could email me back I will call on my nickel. Thanks...
marloweg
12-21-2000 17:11:12
 Re: TEA20 hydraulics-HELP- in reply to Bob, 10-03-2000 17:18:31
if the cover under seat was lifted of with out removing side cover and taking off the frok from pump valve it is broke
rod
10-03-2000 18:24:13
First check out this site it has a diagram and animation of what goes on with the hydraulics. http://www.fofh.u-net.com/ if you still have questions email me direct or check the archives on this site. regards
rod
