help on identifying Harry Ferguson tractor
58pace
06-09-2006 12:42:29
Need help on Identification of my friends tractor in order for ordering manual and parts for it. I will give as much info as I could find on the tractor. On the motor plate is:
Z129 - 377347
Star IN 010-013 EX 010-013 This i believe is for the valves.
Other numbers found on the tractor are:
E44 HF TO-4024A Z128 Bottom of mtr is A600
FIR. Thanks in advance for any help.
Jim in OH
06-09-2006 13:26:58
 Re: help on identifying Harry Ferguson tractor in reply to 58pace, 06-09-2006 12:42:29
Based on your engine serial number, your tractor should be a 1954 TO-30... nearing the last of production... I put together a tractor serial number vs engine serial some time ago and the link is below... this is all assuming that your engine has not been changed... If you have a tractor serial number, it should be about TO-137xxx.. the plate would be under the steering wheel on the front of the dash.. Jim
