TO35 12 volt
Archie
06-12-2006 11:59:45
I have a 1957 TO 35 with a 12 volt electric system, which I just purchased. Doe's anyone know when the Ferguson factory switched from 6 volts? It is equipped with a Freeman Loader. The tilt cylinder leaks pressure not fluid. I am assuming this is a bad O-ring in the valve, how big (or tricky)is this job going to be?
Archie in Ohio
John (UK)
06-12-2006 16:38:04
 Re: TO35 12 volt in reply to Archie, 06-12-2006 11:59:45
If its a double-acting ram, the seals can leak on the piston into the opposite side and leak away like that, this is more common than the spool vale leaking.
they changed to 12v at 161250 in 1955
Archie
06-12-2006 20:18:03
 Re: TO35 12 volt in reply to John (UK), 06-12-2006 16:38:04
Would you test for an internal cylinder leak by plugging the hose couplings?
MERVILLE_BC
08-27-2006 02:45:33
 Re: TO35 12 volt in reply to Archie, 06-12-2006 20:18:03
ANOTHER WAY TO SEE IF THE CYLINDER IS BYPASSING INSIDE IS TO PUT A HEAVY LOAD IN THE BUCKET AND CYCLE THE HYDRAULIC CYLINDER AS MUCH AS POSSIBLE. THEN FEEL THE CYLINDER FOR EXCESS HEAT IN COMPARISON TO THE OTHER CYLINDER. AS THE HYDRAULIC OIL BYPASSES THE PISTON PACKING, HEAT IS GENERATED.
