Jerry, Are you familiar with ignition waveforms, as seen on an ignition oscilloscope? When the breaker points open, and spark occurs, the coil and condensor form a sort of simple resonant tank circuit, and several ocillations occur AFTER the initial spark, due to the actions of the coil's inductance, and the condensor's capacitance.
The coil oscillations are seen at the left of center, as the waveform that tapers off, after the "spark line". It is undesirable to have resistance between the coil and condensor, because it would dampen these oscillations, and make the spark weaker. When you test an ignition condensor on a tester, one of the tests is for lead resistance, and the capacitor will fail the test if an internal poor connection causes excess resistance. Adding the ballast resistor between the coil and distributor would have the same effect as a capacitor that would fail the lead resistance test. Believe this, or not, as you choose, but I feel there is valid reason NOT to put the resistance between the coil and the distributor, and every single factory system I've ever seen that uses a ballast resistor places it between the ignition switch and the coil, NEVER after the coil, so I have to assume the factory engineers think there was a valid reason to set it up that way, too! Go ahead, and set your's up as you choose... there's always a contrarian in every bunch. Most likely, it will work just fine, and you will say "AHA"... my way worked, and I agree with you that it will, but there is the advantage of a slightly "hotter" spark doing it the conventional way, and, likely, breaker point life will be a little better, as the condensor will be able to better do it's job. Remember, energy "bounced" back into the coil by the condensor equals a "hotter" spark, while energy dissipated as heat by an arc across the breaker points is wasted as heat at the points, and anything that affects the designed relationship between the coil and the condensor is likely to cause MORE arcing across the points, as they open. Good luck!
