Voltage Regulator
Archie Ohio
07-17-2006 19:23:04
Can someone refresh my memory on how to polarize the voltage regulator on my TO 35 twelve volt. Thanks
Mike Hornberger
07-18-2006 07:27:37
 Re: Voltage Regulator in reply to Archie Ohio, 07-17-2006 19:23:04
Ron's right... the regulator does not need to be polarized since it just contains relays which work the same no matter which direction current is going. The generator (not alternator - is yours a 12V alternator?) is what needs to be polarized. All you have to do is briefly touch a jumper wire from the generator armature (probably marked with an 'A') to the battery (which ever terminal is not grounded). Manuals on some systems say to do this by connecting the voltage regulator battery terminal 'B' to the voltage regulator generator 'G' terminal which is really just connecting the armature to the battery. That may be where the confusion about polarizing the regulator comes from.
Mike
Ron Lindquist
07-18-2006 06:13:02
Hi, I don't know much about this but don't think you have to polerize voltage reg. Just the generator, which I don't know how to do but I think if you do a search, it was talked about before.
Paul Frohlich 4
03-25-2007 08:54:28
 Re: Voltage Regulator in reply to Ron Lindquist, 07-18-2006 06:13:02
Does the wire from the reg, marked bat, go directly to the positive side of the bat, ( I have a 6 volt positive ground, 47 Fergy,
Archie Cope
07-18-2006 12:16:27
Thanks Fellows.
