Ron, This is basically whimsical thoughts from a guy that has watched a few pulls, but never actually pulled... take it for what it's worth.As you know, you want max torque & HP, which boils down to the lowest gear, and highest RPM possible and still stay below 4 MPH. I negelected to do my homework on this last night, and don't have the necessary info here now. I believe the owners manual has the gear ratios in there, and maybe even the max. ground speed per gear. With a little number crunching, you can calculate the best gear to stay below 4 MPH and nearly full RPMS. From reading a few posts in the archives, I have concluded that the best gearing for pulling is achieved by using a Sherman or Hupp aux. tranny, but that is not essential, as it appears that most tractors in the lighter classes lose traction before the engine gives out. I noticed right away that my local club has NO Fords or Fergys that pull... ever, which is disappointing. Upon investigating the rules, I think I know why. My local club classes tractors by weight, the lightest class is <4000#. SO a Fergy would be pulling against Farmall M's, JD's, MMs, and several other tractors that weigh A LOT more, with bigger tires. The Fergy was made light intentionally, and was built to rely on downpressure from the draft of a plow to provide extra traction... don't have that downpressure when pulling. The heavier tractors will out-traction a Fergy every time. I can't imagine adding 1500#'s of weight to my Fergy to get it up to the weight of those Super M's. I wish the local club had a N/Fergy class... if they did, I would have been pulling by now! Don't know if that helps or not... George
