hood panel help
overunder1
07-26-2006 05:07:15
I have next week off, and having finished all the mechanical updates I want to start repairing the tinwork for final painting. Is there anyone that might have a close up picture of the side of the hood where it joins the front panel? My TO-30 has a pretty good gap between the two pieces on both sides and am wondering if I should MIG the two together and grind smooth or leave the gap in place. Thanks
-Lee
Jim in OH
07-26-2006 09:29:31
 Re: hood panel help in reply to overunder1, 07-26-2006 05:07:15
Depends on your purpose. For Originality, they are just bolted together and the small gap is normal. However, the hood itself is prone to fatigue cracking right at the rearward joint between the dogleg and the hood and the common fix was to weld everything together at this joint (I have seen more that were welded than not.). so if you do weld it, you will not be the only one... (but it might lose points in a show.. :-) Jim
