Hydraulic Top Link
Mick Oz
08-10-2006 16:01:40
If I invest in a hydraulic Top Link will it give my TED 20 the equivalent of down force for the 3pt linkage?
John (UK)
08-10-2006 17:15:23
 Re: Hydraulic Top Link in reply to Mick Oz, 08-10-2006 16:01:40
There is no easy way to apply down force to an implement....and if you do it will remove some weight, which supplies the traction, to the tractor wheels and it will not be able to pull. A hydraulic top link will only alter the length of the top link "hydraulically" not manually and for Cat1 implements that are used on the TE20 it isn't necessary. Just what is the problem you are having that makes you think you need a down pressure, there may be another way to do what you need. Email me at:-
fergusontractors(at)tiscali.co.uk ..... John
