1951 TO30
Mike WH
08-11-2006 11:31:04
How do you remove steering wheel? Does it pull off or unscrew? I have tried both.(gear puller also). Please help!
John (UK)
08-12-2006 12:31:00
 Re: 1951 TO30 in reply to Mike WH, 08-11-2006 11:31:04
Its on a keyed taper and they can really stick tight. They had a three legged puller for this job where the legs used to go under the steering wheel spokes. Just be careful not to damage the steering shaft.
Mike wh
08-13-2006 18:19:24
 Re: 1951 TO30 in reply to John (UK), 08-12-2006 12:31:00
Thanks again John,The three prong puller was a hard item to find. But it worked. I was using a two prong.But it did not work.
Clint1
08-11-2006 12:33:18
I just changed mine last weekend on my TO-20 it took a little hitting with a hammer and removing some of the coating near the center but once you take the acorn nut off a suitable puller should do the trick without too much trouble.
Jerry/MT
08-11-2006 12:07:28
have you done a search in the Archives? I'm sure this topic has come up before numerous times.
