Set carburator
new guy 32
08-15-2006 19:16:35
On my TO-20 how many turns should my carb screws be set at.
Thanks
Jerry/MT
08-15-2006 21:54:56
 Re: Set carburator in reply to new guy 32, 08-15-2006 19:16:35
The Idle air adjustment,(the small screw) should be out 7/8 turns from full closed or until the engine idles smoothly and the main jet (big screw) should be opened 1-1/4 turns. When the engine is warmed up, readjust it to run smoothly under load but do not go less than one full turn out. You need the evaporative charge cooling effect of the richer mixture to prevent valve burning caused by too lean a mixture.
