to-30 ammeter
bilbs
08-23-2006 10:52:17
replaced generator but ammeter still reads in the negative. Battery totally charged.Was told I need to strike generator via batter cables from battery to "set" the generator. This is a positive ground tractor. Any suggestions? Thx
Jerry/MT
08-23-2006 11:11:48
 Re: to-30 ammeter in reply to bilbs, 08-23-2006 10:52:17
You need to polarize the generator. To do this momentarily connect a jumper between the the armature terminal on the generator and the negative terminal of the battery. This must be done before starting the engine.(Reference:Ferguson Shop Manual)
bilbys3
08-23-2006 11:19:03
 Re: to-30 ammeter in reply to Jerry/MT, 08-23-2006 11:11:48
will give it a try. I take it I remove the cable immediately after the engine starts. Does it matter that I have tried this before but with engine already running?
phil(va)
08-24-2006 05:42:00
 Re: to-30 ammeter in reply to bilbys3, 08-23-2006 11:19:03
Just hold it for two seconds, according to the manual. It should spark. Having started it previously shouldn"t make any difference although the manual does say that. If it still doesn"t charge, you may have a genny problem or it may be the voltage reg.
Jerry/MT
08-23-2006 21:10:34
The manual says you could have problems with the generator or the voltage regulator if you do it after strting the first time. I have my doubts though. Can't help you anymore than that.
